Grafana v9.0.2, Ubuntu 20.04.4 LTS -
Restrict anonymous access to view access only on certain dashboards. -
Adjust permissions so that Anonymous can only view certain dashboards. View role has been given to the necessary folder and Dashboard(s), and removed from those that do not need it.
Because I have to give the View role access to the parent folder, all sub-Dashboards inherit that access, including some with button panels. These buttons still work with View only access causing the background code to run. -
What happened?
As above. View users can still action the code associated to buttons. -
None. -
For more detail, it is this button panel I’m using:
I realise that the easiest way could be adjusting where the dashboards are housed, but I want to make sure I’m not missing something, or doing something stupid.
Thanks
