Hello everyone, I was wondering if there is a way to create a vertical separation in a row ? In the same context, will vertical rows be possible in future releases?
best regards.
best regards.
you want an empty space in the middle of a row or more padding between panels? You can use a text panel and in general tab set background to transparent, this will create an empty space on a row.
Ok thanks, that fit to my needs.
