Grafana v11.1.4 -
Vertical Bar Chart -
By running SQL query with backend as Postgres -
What happened?
The query is NOT returning any null values when directly executed in a query editor but Grafana returns null values in the array list. This is resulting in 0 bars for few values. -
The 0 bars should not be visible and only ones with values should be displayed.
you could use a transformation to filter data by values, and exclude the nulls
The values(count(username) are not limited. Everyday there can be new users who can be created. So, canβt use transformation.
The horizontal bars are working as expected. It is only the vertical bars that I am facing issues with.
can you share your postgres query?
select m.punch_time::timestamp::date as time, u.email, count(u.email)
FROM
punch m
JOIN
users u ON u.id = m.user_id
WHERE
punch_time between β${__from:date:iso}β AND β${__to:date:iso}β
group by m.punch_time::timestamp::date, u.email;
can you share a table view export of your query result?
I have the same question/issue. Did you find a solution for this?
