Variables no longer work on my Grafana dashboard (error updating options: undefined is not an object (evaluating 'e.fields'))
    Grafan v9.3.2 (21c1d14e91)
    Ubuntu 22.04.1 LTS
    I want to use a variable in my queries.
    I am using GitHub as a datasource and I am trying to retrieve labels from a GitHub repo. This worked previously but suddenly stopped working. I updated the docker grafana image but this did not solve the problem.
  • What happened?
    The dropdown lists in my dashboards for the variables I’ve created are now empty.
    I expect these dropdown lists to be populated with the GitHub labels that match my regex.
    Docker container logs
    logger=context userId=0 orgId=0 uname= t=2023-01-04T16:28:01.969982674Z level=warn msg=“Received invalid referer in request headers, removed for log forgery prevention”
What datasourxe are you querying to get your variable list? Github?
What query language?
Hi @yosiasz. Yes I’m querying Github for a list of labels in a repo and then I want to use these variables to query a mysql database.
What happens if you ran that exact query outside of grafana?
It works fine. I get the list of labels in the repo.
If I can provide you with any more information let me know!
yes you’re right, that was it, thank you very much!
