Grafana cloud (trial) 9.3.6 -
Set a variable for my first dashboard using Azure Data Explorer datasource -
Following the steps here grafana/azure-data-explorer-datasource: Grafana datasource plugin for Microsoft Azure Data Explorer (formerly Azure Kusto) (github.com) -
What happened?
No values are returned in variables, including in the previewing on variable configuration. The datasource is all good, and I have a panel with chart from the same database. -
Expected values are returned in variables, including in the previewing on variable configuration. Note that the datasource is all good, and I have a panel with chart from the same database.
Note: Here is table view dashboard of variables data I expected.
