Hi Grafana Community,
We recently upgraded our Grafana instance from v10.4.19 to v12.4.3 and encountered a critical issue with variable passing in dashboards that use a custom datasource plugin (which is now deprecated and stopped updates since Jan 1st).
Problem Summary
In dashboards like “Service Report”, variables such as
DeviceType,DeviceName,Active,Columnsetc. are no longer passed correctly to the backend datasource service. -
As a result, sub-device data (e.g., reachability and availability) cannot be retrieved.
Root Cause (observed)
By comparing the /query request payloads between v10 and v12, we found that the scopedVars structure has changed abnormally:
Grafana v10.4.19 (working as expected):
json
"scopedVars": {
"DeviceType": {...},
"DeviceName": {...},
"Active": {...}
Grafana v12.4.3 (broken):
json
"scopedVars": {
"undefined": {...}
All variable keys are replaced with the literal string
"undefined". -
Multiple variables are reduced to only the last one.
The
targets[0].datafield remains unchanged and still contains the correct variable values.
Additional Context
The custom datasource plugin acts as a bridge between Grafana and our backend service.
The plugin is no longer maintained (last update: Jan 1, 2023).
The issue only appears after upgrading to Grafana v12; v10 works fine.
We are aware that this might be a known Grafana v12 bug (still present in v13 according to some sources).
Our Question to the Community
Is this a confirmed Grafana core bug related to
scopedVarshandling in v12+? -
Are there any known workarounds (e.g., plugin-side patches, configuration flags, or frontend hooks) that can restore correct variable passing without downgrading Grafana?
If we were to develop a new custom datasource plugin to replace the deprecated one, what is the recommended way to retrieve dashboard variables reliably in v12+ (e.g., reading from
targets[0].datainstead ofscopedVars)?
Environment
Grafana versions: v10.4.19 (working), v12.4.3 (broken), also tested v13 (still broken)
Datasource plugin: custom JSON/HTTP plugin (EOL since Jan 1, 2023)
Backend: custom service that receives transformed queries from the plugin
