I have a dashboard variable called “filename”, which looks like
v1.tagValues(
bucket: v.bucket,
tag: "ff",
predicate: (r) => true,
start: -1d
It gives me values of the key for “ff”.
The values look like: /tmp/a/b, /sbin, /etc/cron
So my grafana query look like
filter(fn:(r) => r["ff"]=~ /^${filename:pipe}$/)
i keep getting invalid: compilation failed
grant2
2
Do any of these work?
|> filter(fn: (r) => r["ff"] == "${filename}")
|> filter(fn: (r) => r["ff"] =~ /${filename:regex}/)
|> filter(fn: (r) => r["ff"] =~ /^${filename:regex}$/ )
You need to ecape regular expression metacharacters in your variable, so valid regexp will be generated:
I really appreciate it. Thanks a lot
grant2
5
Which expression worked (if any)?
