my variable is part of the topic that i need to query different values from my database influx,
I defined this variable of name: M1, with label machine
SELECT value FROM “sensors_mqtt_consumer” WHERE (“topic” = ‘/id_machine’)
this query return the numbers of my machines
so to be able to select a different value i really would like to write something like this, but i dont work
i really dont understand why
SELECT value
WHERE (“topic” = ‘/^macchina’/info/Vacuum_Current ')
if i change write (“topic” = ‘/2/info/Vacuum_Current ')
it works very well, i need to change that number at run-time with the variable so the query will resolve differents data.
someone can help me?
