OSS V10.0 linux - What are you trying to achieve?
Add a variable filter on my dashboard, where ES is the datasource I’m using - How are you trying to achieve it?
Add a variable filter on my dashboard - What happened?
Not sure how to do - What did you expect to happen?
Something like this - Can you copy/paste the configuration(s) that you are having problems with?
there is no configuration here yet - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No - Did you follow any online instructions? If so, what is the URL?
No
