[v10.1.9]
An InfluxDB query with a math operation that involves a variable with a decimal point
What happened?
the decimal point is preceded by inserted two back slashes
not to insert the two back slahes
Desired InfluxDB query where $consthousesizem2 is 2744.59:
SELECT sum(“jednotky”)/$consthousesizem2 as dumm2 FROM (SELECT spread(“value”) as jednotky FROM “teplo_kWh” WHERE $timeFilter GROUP BY “unit”::tag fill(null))
Correct query variable evaluation when no expression is involved:
q:“SELECT sum("jednotky")/2744.59 as dumm2 FROM (SELECT spread("value") as jednotky FROM "teplo_kWh" WHERE time >= now() - 30d and time <= now() GROUP BY "unit"::tag fill(null))”
Failing query variable evaluation when an expression is added (variable decimal point with two back slahes):
query:“SELECT sum("jednotky")/2744\\.59 as dumm2 FROM (SELECT spread("value") as jednotky FROM "teplo_kWh" WHERE $timeFilter GROUP BY "unit"::tag fill(null))”
The expression shows that if it exists then the query is not working any more. In other words its existence breaks the query (breaks the variable evaluation)
Just $A does not make any sense - just keeping it as simple as possible
My wild guess is when Grafana sees the variable with a floating-point value (2744.59) being used in the query, it likely anticipates potential issues with the period being interpreted as a regex wildcard. To prevent this, it automatically adds a backslash to escape the period. However, since the backslash itself is a special character in many contexts (including string formatting), Grafana adds another backslash to escape the first one. This results in the double backslash (\\.) you’re seeing.
The above syntax might have to be changed to something like:
Thanks for the guess, but the above syntax cannot be changed as you propose. The $consthousesizem2 variable is not a tag here. It is just a number for a math operation. The strange thing is that it works until a new Expression is added (see the pictures).
I found a clue with Query inspector and $timeFilter variable:
if there is only query like:
Query inspector says:
executedQueryString:“SELECT spread("value") as jednotky FROM "teplo_kWh" WHERE time >= now() - 30d and time <= now() GROUP BY "unit"::tag fill(null)”
However, if an Expression is added, then the Query inspector says:
executedQueryString:“SELECT spread("value") as jednotky FROM "teplo_kWh" WHERE time >= 1747044580254ms and time <= 1749636580254ms GROUP BY "unit"::tag fill(null)”
It means that if a single Expression is added the variables ($timeFilter in this case) is handled differently.
If the $timeFilter is replaced by another variable with a dot inside (i.e. variable consisting UTC timestamp with a dot - “2017-11-07T15:12:37.121Z”) then the Query combined with Expression gets broken and it stops to work.
