Hi! I have an issue i need som input on from someone. So on beforehand, thanks for any guidance im given
Im using panel repeating to show data on uniqe MQTT topics that exists of spesific types.
Using the repeater itself works like a charm on whole topics.
This is my MQTT topic: “OC1/DATA/VAR/VAL/PQLPXK/ProcessingLines/LineA/GCR” and it works in the repeater.
My issue seems to be this:
Im trying to find a way to merge this string"OC1/DATA/VAR/VAL" with each selectable variable containing this format “/PQLPXK/ProcessingLines/LineA/GCR”. The output should then be used in the repeater.
This is done so that i can use this partial topic to select machine: “/PQLPXK/ProcessingLines/LineA/GCR”, and this partial topic to select data format to be presented in the spesific panels : “OC1/DATA/VAR/VAL”.
Thanks for taking time to answer me @grant2 , i appreciate it
I found a way to do it thru use of variables.
Here si a copy of the code i used if anyone else is interested:
SELECT
time,
(data->>‘value’)::Numeric AS DetectedSpeedPrMin
FROM
datavalues
WHERE
topic IN (
SELECT
STRING_AGG(CONCAT(‘OC1/DATA/VAR/VAL’, topic, ‘/GCR’), ‘,’)
FROM
(SELECT unnest(string_to_array(${topic_line}, ‘,’)::text) as topic) subquery
AND data ->>‘name’=‘FishDetectedPrMin’
AND time > $__timeFrom()
AND time < $__timeTo();
It gave me the ability to spesify a LineA, and then add he machinery(example GCR) tot he Row repeater. It aslo game me the ability to spesify the first section of the MQTT topic so that i could fetch the different data types on each machine.
