Hi all,
Im using graphite (0.9.16) with grafana (4.5.2) and build a dashboard showing some Singlestats.
One row I configured with Value-Stat=current and the other row I configured with Value-Stat=avg.
I assumed, that the values displayed for the Singestats with stat=current stay the same nevertheless which timeranges I pick. Since current means “last” value. But when I switch from “last 5 minutes” to “last 2 days” the values changed. Between “last 5 minutes” and “last 1 hour” the values are the same.
Is that a bug? Or configuration error?
my graphite storage-schemas:
[carbon]
pattern = ^carbon.
retentions = 60:90d
[icinga_internals]
pattern = ^icinga2\..*\.(max_check_attempts|reachable|current_attempt|execution_time|latency|state|state_type|acknowledgement|downtime_depth)
retentions = 5m:60d
[icinga_agent_metrics]
pattern = ^icinga2\..*\.services\.icinga\.
retentions = 1m:7d,5m:30d
[icinga_default]
retentions = 1m:60d,5m:180d,10m:5y
[default_1min_for_1day]
pattern = .*
retentions = 60s:1d
the icinga_default should apply here.
