In my datasource plugin I used value-select-dropdown component implemented in
public\app\core\directives\value_select_dropdown.js(ts) (Grafana versions from 4 to 7.0.6)
Since Grafana 7.1.0 component was removed and my plugin stop working properlly.
Is there any real possibility to use value-select-dropdown component on all Grafana versions since 4?
