I want to calculate the difference of two values in a query for a some days
SELECT difference(last(value)) FROM “MyMeasurement1”
WHERE time >= now() - 5d
GROUP BY time(1d)
then I get the values I want to see for “MyMeasurement1”. This works…
My question is now: How can I calculate the same for ten different measurements of my database? Is it possible to get the difference of the last 10 days for more than one measurement (“MyMeasurement1”, “MyMeasurement2”, “MyMeasurement3”… ) or do I have to do it ten times for each measurement?
At the moment I use grafana 10.4.1 on a raspberry pi.
Thank you!
Regards
Thomas
