Summing up the current value of multiple measurements of Influx
I have an influx database some_db with multiple measurements measurement1, measurement2 that contain timeseries data. I want to query the sum of the most recent value of each of these.
I’ve attempted this query
> SELECT last("value") FROM "measurement1"+last("value") FROM "measurement2" fill(previous)
but get this error:
ERR: error parsing query: found +, expected ; at line 1, char 54
Sounds like your data could be better shaped into 1 measurement with proper use of tags.
If limited to working with your data as is, try individual queries for each measurement and then a transformation to reduce down to sum.
Otherwise read up on flux for ultimate control of your own destiny :grinning:
