Validation tool for a dashboard
we use Grafana 7.2.0, but our customers want to use the dashboards in different Grafana versions. Although Grafana automatically updates the dashboards to the new version during import, I’m interested in something else. Can we check beforehand whether the respective dashboard is compatible for a specific Grafana version? Sometimes small things don’t work after the import, which then have to be fixed by hand.
I was thinking of a validator that would check the json file, for example, or some comparable mechanism.
I am grateful for every suggestion.
Many Thanks
Hi @mermaid,
Thanks for opening this post.
There seems to a one available. Please check it out:
Let us know if this helps.
