Does k6 provide a UUID function to generate a string that like the format shown in the example below?
The following example, the UUID function is provided in Jmeter.
Hi @sunnini !
The k6 utils have a uuidv4 generator. Does it fit your needs?
Let me know if that helps,
Cheers!
uuidv4 fit my need, thanks~
