I want to generate the random GUID in k6.
Followed the below link to generate the random UUID.
Getting the below error:
Requesting you to help with the same.
Hello!
It looks like browserify generates the file in “UTF-16 Little Endian” encoding. Switching the encoding to “UTF-8 with BOM” solves the problem.
The easier solution is probably just to use the UUID library from jslib as documented here:
import { uuidv4 } from "https://jslib.k6.io/k6-utils/1.0.0/index.js";
export default function() {
let randomUUID = uuidv4();
console.log(randomUUID); // 35acae14-f7cb-468a-9866-1fc45713149a
