TLDR;
I basically have a search that gives result X and I want to create teh same search using a variable but this gives me a different result. Not sure why.
v7.5.6
use a custom vaiable in a search/query
defining the variable in the dashboard settings
What happened?
The full search on its own gives value X when i usee the same search with the variable I get value Y(slightly different to value X) . The difference may be negligible and or rounding error but how do i confirm this?
I expect to get the same values.
NA
NA
No
Example search without variable:
eventType:DeviceRequestResponseEvent
AND (exists:payload.cattle.name)
AND (farmId:e9740d29-b56f-43f4-8102-1508708be6cf OR
farmId:9e89605f-f2b5-4375-8f8a-05b043bc35b5 OR
farmId:f0470248-3c89-4914-9e58-d3ba49929de8 OR
farmId:01a46754-2531-4cb4-bfac-bf79417e9e97 OR
farmId:e4c634d3-f56e-410e-a357-5ae5fe9305f8 OR
farmId: 2be6f728-c755-4d59-9069-a0f834ae63d0 OR
farmId:4ef316f1-4628-4457-9468-1a294d1e7769 OR
farmId:1bf35dbc-ce2b-4a2c-b126-7cd531aa84ad OR
farmId:067c2d29-40b9-41c9-810e-6ee7fc6c733f OR
farmId:2cf7b168-d1d7-4097-ba15-ffb722559b60 OR
farmId:aee7f216-ccad-4a6c-9586-b910a4d99a12 OR
farmId:27c89d41-e4cf-40a7-8276-5bce52534edd OR
farmId:caabcc99-4274-46ea-b563-533fa8b31dc1 OR
farmId:cc7e50e8-ae69-48f8-9e4c-61fbf2e46628)
AND payload.deviceRequestResponseEvent.payloadType:COMMAND_REQUEST_TYPE
Example search with variable:
${var_for_all_farms}
LHS is one without variable
RHS is one with variable
LHS: "query": "eventType:DeviceRequestResponseEvent\nAND (_exists_:payload.cattle.name)\nAND (farmId:e9740d29-b56f-43f4-8102-1508708be6cf OR \nfarmId:9e89605f-f2b5-4375-8f8a-05b043bc35b5 OR \nfarmId:f0470248-3c89-4914-9e58-d3ba49929de8 OR \nfarmId:01a46754-2531-4cb4-bfac-bf79417e9e97 OR \nfarmId:e4c634d3-f56e-410e-a357-5ae5fe9305f8 OR \nfarmId: 2be6f728-c755-4d59-9069-a0f834ae63d0 OR \nfarmId:4ef316f1-4628-4457-9468-1a294d1e7769 OR \nfarmId:1bf35dbc-ce2b-4a2c-b126-7cd531aa84ad OR \nfarmId:067c2d29-40b9-41c9-810e-6ee7fc6c733f OR \nfarmId:2cf7b168-d1d7-4097-ba15-ffb722559b60 OR \nfarmId:aee7f216-ccad-4a6c-9586-b910a4d99a12 OR \nfarmId:27c89d41-e4cf-40a7-8276-5bce52534edd OR \nfarmId:caabcc99-4274-46ea-b563-533fa8b31dc1 OR \nfarmId:cc7e50e8-ae69-48f8-9e4c-61fbf2e46628)\nAND payload.deviceRequestResponseEvent.payloadType:COMMAND_REQUEST_TYPE",
farmId:2be6f728-c755-4d59-9069-a0f834ae63d0 OR
I thought the AND was missing but that is at the start of the variable. But maybe I should remove it from the variable and place it in the search.
what does your data look like?
how do I look at the data? do you mean the csv I can download? tks!
