tcl
1
8.1.2, Official Docker
I am trying to use the current value of a template variable to populate the tag field of annotations.
Ideally, I would love to use it in key:value format, such as:
site_id:$site_id
I am using: $my_template_variable_name when defining tag in new annotations popup.
What happened?
It is treated as a string “$my_template_variable_name” instead of entering the variable value (e.g. 1234)
The tag is created using the value (e.g. 1234)
No errors seen
Hi @tcl
I believe that this is an ongoing feature request. Here is an issue with a lot of recent chatter:
system
Closed
3
