Grafana v7.3.1 (6668161a88) on Linux (official Docker image)
I’m using the JMX Exporter to collect metrics from several Tomcat instances. Each instance has a different set of DB pools. I would like to have a single dashboard with all the time series for all DB pools of all instances.
Example:
- instance
foo
, pool nameoracle_1
- instance
foo
, pool nameoracle_2
- instance
bar
, pool namemysql
- instance
baz
, pool nameoracle_1
(note, coincidentally same as above) - instance
baz
, pool namepostgres
At first I tried using two template variables, one for the instances and one for the pool names, using one for the rows and the other for the inner panel, but I found out that it’s not possible.
The two distinct variables are:
- instance:
label_values(up{job='jmx'}, instance)
- pool name:
label_values(tomcat_dbpool_numactive, name)
And the way I can use them in my panel:
tomcat_dbpool_numactive{instance=~"$container", name=~"$name"}
But the result is a table with the outer product of all possible instances × pool names, which in my case is mostly empty (eg. there is no pool oracle_1
on bar
, there is no oracle_2
on bar
nor baz
, etc.)
Therefore I’d like to define a single variable with the actual combinations of values for instance × pool name. For example:
foo:oracle_1
foo:oracle_2
bar:mysql
baz:oracle_1
baz:postgres
But I have no idea how to define such a variable, let alone how to use it in my queries.
