MAC OS, Grafana v11.2.1 -
I am trying to create an alert, but first Im testing my queries out in the dashboard section. Each Access Point has totalMemory and availableMemory, I am trying to create an alert for access points which have increasing memory. -
I am trying to achieve this by using diffrentiation function and seeing how the slope changes with time, if it increases for more than a set period of time then I throw an alert. -
What happened?
The diffrentiation function is supposed to take in output from another bunch of queries. But Im unable to figure out how this can be done, I tried the dashboard data source method, but in that you can just view the output of another panel in some other panel. -
I expected that I’ll be able to query output of another query here itself, but is there a workaround this? -
A: SELECT mean(“value”)
FROM “$database”.“$measurement_total”
WHERE (“$tag1”::tag =~ /^$value1$/ AND “$tag2”::tag =~ /^$value2$/)
AND $timeFilter
GROUP BY time($__interval)
fill(none)
B: SELECT mean(“value”)
FROM “$database”.“$measurement_available”
AND $timeFilter
fill(none)
Math expression (($A-$B)/$A)*100 -
I have received no errors -
I tried following Referencing value from one query to another - #5 by sahebdatta1996
but quickly realised that I can only apply transformations if I use dashboard as datasource and not more complex queries like I want to.
Welcome @shreyamalik to the Grafana forum.
So no errors, but no output either, right?
I am thinking that perhaps the timestamps of the results from Query A and Query B are not aligned. Maybe try experimenting with the fill function?
Also, are you using InfluxQL?
Yes I am using InfluxQL, so the queries I have written are working perfectly fine, but my doubt is that I want to apply a query on the output of these queries, and then a math transformation on that to create an alert. What are my possible solutions to build a query on top of another query.
