Using Grafana for application mapping
I want to use Grafana to make an application mapping. So i want to know if there is a way to do it with a plugin or with a native way.
Thanks
Welcome to forum
Something like this ?
Yes something like that
You can do it using native Node Graph panel
Alternative is Apache ECharts for more customization options and event handling
Whaat plugin did you use ?
I would say your “application mapping” is service graph, which is generated from traces:
Hii
You can create application mappings in Grafana using plugins, custom dashboards, or by integrating with third-party tools like Prometheus or Jaeger for metrics and traces visualization. Choose the method that suits your needs best.
