v9.5.1 Windows 11 -
Setting a certian time variable as the target of the time selection in the top right by using an alias. TL;DR Can an alias be used in the $__timeFilter() command? -
I have a nested SQL query akin to the following:
select name
, (select MAX(Created) from timesheet where id = timesheet.id) as time
, (select something from somethingelse) as something
, date
, color
Where $__timeFilter(time) -
What happened?
Sheet errors out 1064 -
I expected my named variable to be the target of the time slice in the top right (dropdown) -
Due to the propritay nature of my code, I cannot. -
Status: 500. Message: db query error: Error 1064: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘.Created BETWEEN FROM_UNIXTIME(1659029162) AND FROM_UNIXTIME(1690565162) #…’ at line 22 -
No
