User permissions in annotations api
Hello from Ireland, this is my first post here. It’s a great forum!
I want to use the annotations api, but I was wondering if there’s any possibility to give permissions to add annotations only on defined dashboards. If I’m not wrong if you don’t specify the dashboard id, it will add the annotations for all dashboards.
I was thinking on this because it’s not difficult to forget adding the dash id and I don’t want to add that to all of the dashboards by default.
Maybe It’s much simpler than that!
Thank you so much.
