User details in log files
Are the user details logged with each activity that is performed by the user? For example, user X is logged into Grafana, will the login time be logged into the Grafana logs? Same question for other activities performed by user X (using existing dashboard, creating a new dashboard, logging out of Grafana, etc.
In addition to the above, if such details are truly logged, is it possible to configure Grafana not to log this information (or maybe even to mask the user details)?
Any help will be appreciated.
Thanks!!!
welcome to the :grafana: forum, @iperfectdealz
you can set the logging verbosity and see for yourself:
Check if it helps. I’ve created a shell script to check how many days a user has logged. Simple but useful.
