I have a dashboard that uses a variable, with the following query:
label_values(node_exporter_build_info, instance)
The previous query will give a drop-down list at the dashboard, to check the static and the server, like (CPU, MEM, …).
I added a new exporter (BlackBox) that will get a status of a health check.
Also, I added another query, like the following:
label_values(probe_success, job)
My question is how to set one variable to read from the node exporter, and BlackBox values, of Prometheus.
Can the query be, for example:
label_values(probe_success, job) AND label_values(node_exporter_build_info, instance)
