Grafana 9.3.1 on Debian 11
I have a dashboard with 3 variables:
- datasource (a centralised prometheus server)
- boxname: label that is applied to all metrics that are scraped from a given target server
- services: label that is applied to each distinct scraped target inside a given target server
=> 2 distincts target servers shares some of the service labels but have also specific ones.
After selecting a box name, the services dropdown should only display values for services that are effectively present on this server.
I have:
Variable | Definition | |||||
datasource | prometheus | |||||
boxname | label_values(boxname) | |||||
service | label_values(service) |
But the service variable does not depend on boxname and so all services for all servers are shown in the drop down.
How can i restrict the list ?
I tried to carefully dig the doc e.g: Prometheus template variables | Grafana documentation
and the forum without success, but might have missed something because it seems to be quite a classic requirements
Among others, I could not find the syntax to use the query_filter(query)
for prometheus DS that sounds promising.
