Grafana v9.5.13 (802385ecac) (Azure Managed Grafana) -
I have two queries, that I am merging. Afterwards I want to group the results by one column and get the values from the record that has the highest value for a certain property.
Example:
Query Result1:
| Item | Order |
| ItemA | OrderX |
| ItemB | OrderX |
Query Result2:
| Item | Weight |
| ItemA | 24g |
| ItemB | 217g |
Now after merging I get
| Item | Order | Weight |
| ItemA | OrderX | 24g |
| ItemB | OrderX | 217g |
Now I would like to group by Order and get the record, that has the highest weight,so I want:
- How are you trying to achieve it?
I tried the group by function, but none of the calculation seem to do what I want. I also tried to achieve this via an expression of the queries, but to no result. I also read through all other transformations, but I have not come up with a series of transformation, that would achieve what I am going for …
