Use Alerting Contact Points from OnCall
Hello, I’m setting up Grafana OnCall.
OnCall itself does not support the platforms I need and I’d like to keep the system simpler than custom webhooks with a huge amount of templating.
The Contact Points from Alerting do support what I need, so is there a way to forward alerts from OnCall to Alerting in order to use those Contact Points?
As far as I know, this is not feasible.
Which integration do you need for Grafana OnCall? For feature requests, suggest opening a GH issue in the OnCall repo.
Thanks for the response.
I guess OnCall is more oriented towards chat ops. That’s not really what I want/need, so I settled on building notifications directly in my monitoring system instead.
