Grafana v10.2.1 - hosted on debian as docker -
Trying to Query a JQL file using the Infinity-plugin and UQL script -
A snip of my JSON file
"project_name": "TRA BT M7 Audio & Displays",
"project_key": "TRA_BT_M7",
"release_name": "M7_FS_SWPx.x.x",
"release_released": false,
"release_start_date": null,
"release_expected_end_date": null,
"release_end_date": null,
"release_issue_count_done": 2,
"release_issue_count_in_progress": 0,
"release_issue_count_to_do": 2,
"release_issue_count_total": 4,
"coupled_test_cycle_lines": [
"project_key": "",
"project_name": "",
"test_cycle_name": "no test cycle found",
"test_cycle_environment": "",
"release_name": "",
"results_passed": 0,
"results_failed": 0,
"results_incomplete": 0,
"results_blocked": 0,
"results_not_tested": 0,
"results_na": 0,
"results_total": 0,
"defects_resolved": 0,
"defects_open": 0,
"defects_total": 0
"project_requirement_count_with_passed_test_runs": 0,
"project_requirement_count_with_failed_test_runs": 0,
"project_requirement_count_covered_no_test_result": 0,
"project_requirement_count_covered": 0,
"project_requirement_count_uncovered": 0,
"project_requirement_count_total": 0,
"release_nc_count_open_minor_low": 0,
"release_nc_count_open_minor_high": 0,
"release_nc_count_open_major": 0,
"release_nc_count_total": 2,
"jenkins_job_name": null,
"jenkins_job_description": null,
"jenkins_job_branch_name": null,
"jenkins_job_branch_health_score": null,
"jenkins_job_branch_last_build_result": null,
"jenkins_job_branch_last_build_number": null
"project_name": "TRA W&B",
"project_key": "TRA_STA_CL_WB",
"release_name": "Citylink_FS_SWP3.05-RC_INT",
"release_released": true,
"release_expected_end_date": "2023-09-12",
"release_end_date": "2023-09-12",
"release_issue_count_done": 1,
"release_issue_count_to_do": 1,
"release_issue_count_total": 2,
"test_cycle_name": "Testcycle SWP3.5.0",
"release_name": "",
"results_passed": 73,
"results_failed": 13,
"results_blocked": 13,
"results_not_tested": 77,
"results_na": 0,
"results_total": 176,
"defects_resolved": 1,
"defects_open": 12,
"defects_total": 13
"test_cycle_name": "SWP3.5.0",
"release_name": "",
"results_na": 0,
"results_total": 0,
"defects_open": 0,
"defects_total": 0
"project_requirement_count_with_passed_test_runs": 2,
"project_requirement_count_with_failed_test_runs": 4,
"project_requirement_count_covered": 6,
"project_requirement_count_total": 6,
"release_nc_count_open_minor_low": 1,
"release_nc_count_total": 1,
"jenkins_job_name": "46.00.0032",
"jenkins_job_description": "SYS Wales and Borders",
"jenkins_job_branch_name": "release/3.5.0",
"jenkins_job_branch_health_score": 100,
"jenkins_job_branch_last_build_result": "SUCCESS",
"jenkins_job_branch_last_build_number": 13
I want to build a UQL query that filters that item, where “release_name”== “Citylink_FS_SWP3.05-RC_INT”, then I want to mv-expand " “coupled_test_cycle_lines”. So it results in a data-table with test_cycle_lines.
I tried:
parse-json
| where "release_name" = "Citylink_FS_SWP3.05-RC_INT"
| mv-expand "coupled_test_cycle_lines"
But not working ![]()
Trying the UQL below works and results in the table I want, however I need to be able to filter on “release_name” using a dashboard variable. (Above I used a test value ‘Citylink_FS_SWP3.05-RC_INT’)
parse-json
