Uptime is N/A on CentOS 7
Dears,
Im new with Grafana
I just install the grafana successful as follows:
A. My Environment:
  1. Grafana 10.2.3
  2. InfluxDB shell version: 1.8.10
  3. telegraf
    [global_tags]
Configuration for telegraf agent
[agent]
interval = “10s”
debug = false
hostname = “localhost”
round_interval = true
flush_interval = “10s”
flush_jitter = “0s”
collection_jitter = “0s”
metric_batch_size = 1000
metric_buffer_limit = 10000
quiet = false
logfile = “”
omit_hostname = false
OUTPUTS
[[outputs.influxdb]]
urls = [“http://localhost:8086”]
database = “telegraf-db”
timeout = “0s”
username = “testuser”
password = “yourstrongpassword”
retention_policy = “”
INPUTS
[[inputs.cpu]]
percpu = true
totalcpu = true
collect_cpu_time = false
report_active = false
[[inputs.disk]]
ignore_fs = [“tmpfs”, “devtmpfs”, “devfs”]
[[inputs.diskio]]
[[inputs.kernel]]
[[inputs.mem]]
[[inputs.processes]]
[[inputs.swap]]
[[inputs.system]]
[[inputs.netstat]]
  1. Host Dashboard with ID 10581
B. My Problem:
Uptime on hostDashboard of Localhost is N/A
Can you check and fix help me.
Thank you so much for your support.
can you try running the following test:
telegraf --test --config /path_to_your_config_file
Here is result.
[root@localhost ~]# telegraf --test --config /etc/telegraf/telegraf.conf
2024-01-05T08:16:29Z I! Loading config: /etc/telegraf/telegraf.conf
2024-01-05T08:16:29Z I! Starting Telegraf 1.29.1 brought to you by InfluxData the makers of InfluxDB
2024-01-05T08:16:29Z I! Available plugins: 241 inputs, 9 aggregators, 30 processors, 24 parsers, 60 outputs, 6 secret-stores
2024-01-05T08:16:29Z I! Loaded inputs: cpu disk diskio kernel mem net netstat processes swap system
2024-01-05T08:16:29Z I! Loaded aggregators:
2024-01-05T08:16:29Z I! Loaded processors:
2024-01-05T08:16:29Z I! Loaded secretstores:
2024-01-05T08:16:29Z W! Outputs are not used in testing mode!
2024-01-05T08:16:29Z I! Tags enabled: host=localhost
2024-01-05T08:16:29Z W! DeprecationWarning: Value “false” for option “ignore_protocol_stats” of plugin “inputs.net” deprecated since version 1.27.3 and will be removed in 1.36.0: use the ‘inputs.nstat’ plugin instead
diskio,host=localhost,name=sr0 io_time=521i,iops_in_progress=0i,merged_reads=0i,merged_writes=0i,read_bytes=1052672i,read_time=678i,reads=18i,weighted_io_time=678i,write_bytes=0i,write_time=0i,writes=0i 1704442589000000000
diskio,host=localhost,name=dm-0 io_time=1190218i,iops_in_progress=0i,merged_reads=0i,merged_writes=0i,read_bytes=2616546816i,read_time=2273697i,reads=92296i,weighted_io_time=3893970i,write_bytes=5086822400i,write_time=1593512i,writes=540606i 1704442589000000000
diskio,host=localhost,name=dm-1 io_time=1671499i,iops_in_progress=0i,merged_reads=0i,merged_writes=0i,read_bytes=1690517504i,read_time=3765097i,reads=412261i,weighted_io_time=581719838i,write_bytes=5238575104i,write_time=575169487i,writes=1278949i 1704442589000000000
diskio,host=localhost,name=sda io_time=2577315i,iops_in_progress=0i,merged_reads=253187i,merged_writes=1301662i,read_bytes=4338141696i,read_time=4238838i,reads=252666i,weighted_io_time=10818652i,write_bytes=10327535616i,write_time=7148635i,writes=517868i 1704442589000000000
diskio,host=localhost,name=sda1 io_time=14176i,iops_in_progress=0i,merged_reads=0i,merged_writes=0i,read_bytes=27321344i,read_time=15615i,reads=2106i,weighted_io_time=15830i,write_bytes=2138112i,write_time=219i,writes=16i 1704442589000000000
diskio,host=localhost,name=sda2 io_time=2576061i,iops_in_progress=0i,merged_reads=253187i,merged_writes=1301662i,read_bytes=4309235200i,read_time=4223123i,reads=250529i,weighted_io_time=10802597i,write_bytes=10325397504i,write_time=7148416i,writes=517852i 1704442589000000000
disk,device=dm-0,fstype=xfs,host=localhost,label=centos-root,mode=rw,path=/ free=23195049984i,inodes_free=16179734i,inodes_total=16248832i,inodes_used=69098i,inodes_used_percent=0.4252490271300731,total=33261359104i,used=10066309120i,used_percent=30.26427479564246 1704442589000000000
disk,device=sda1,fstype=xfs,host=localhost,mode=rw,path=/boot free=859734016i,inodes_free=523954i,inodes_total=524288i,inodes_used=334i,inodes_used_percent=0.0637054443359375,total=1063256064i,used=203522048i,used_percent=19.14139546351085 1704442589000000000
system,host=localhost load1=0.08,load15=0.15,load5=0.08,n_cpus=4i,n_unique_users=1i,n_users=1i 1704442589000000000
system,host=localhost uptime=278604i 1704442589000000000
system,host=localhost uptime_format=“3 days, 5:23” 1704442589000000000
swap,host=localhost free=4841533440i,total=8594124800i,used=3752591360i,used_percent=43.664613294887225 1704442589000000000
swap,host=localhost in=1688252416i,out=5238575104i 1704442589000000000
mem,host=localhost active=6386786304i,available=202858496i,available_percent=2.47944765880285,buffered=0i,cached=387584000i,commit_limit=12684922880i,committed_as=18693341184i,dirty=122880i,free=144216064i,high_free=0i,high_total=0i,huge_page_size=2097152i,huge_pages_free=0i,huge_pages_total=0i,inactive=1314295808i,low_free=0i,low_total=0i,mapped=156737536i,page_tables=53981184i,shared=81866752i,slab=91144192i,sreclaimable=39718912i,sunreclaim=51425280i,swap_cached=349110272i,swap_free=4841533440i,swap_total=8594124800i,total=8181600256i,used=7649800192i,used_percent=93.50004831133124,vmalloc_chunk=35183933779968i,vmalloc_total=35184372087808i,vmalloc_used=196370432i,write_back=0i,write_back_tmp=0i 1704442589000000000
net,host=localhost,interface=ens36 bytes_recv=42257353i,bytes_sent=87513173i,drop_in=41797i,drop_out=0i,err_in=0i,err_out=0i,packets_recv=246062i,packets_sent=106388i 1704442589000000000
net,host=localhost,interface=ens33 bytes_recv=152094502i,bytes_sent=141149061i,drop_in=13i,drop_out=0i,err_in=0i,err_out=0i,packets_recv=896476i,packets_sent=190354i 1704442589000000000
kernel,host=localhost boot_time=1704163986i,context_switches=381629261i,entropy_avail=3324i,interrupts=217715761i,processes_forked=455733i 1704442589000000000
net,host=localhost,interface=all icmp_inaddrmaskreps=0i,icmp_inaddrmasks=0i,icmp_incsumerrors=0i,icmp_indestunreachs=2320i,icmp_inechoreps=13207i,icmp_inechos=3i,icmp_inerrors=1i,icmp_inmsgs=15531i,icmp_inparmprobs=0i,icmp_inredirects=0i,icmp_insrcquenchs=0i,icmp_intimeexcds=0i,icmp_intimestampreps=0i,icmp_intimestamps=0i,icmp_outaddrmaskreps=0i,icmp_outaddrmasks=0i,icmp_outdestunreachs=2351i,icmp_outechoreps=3i,icmp_outechos=13213i,icmp_outerrors=0i,icmp_outmsgs=15567i,icmp_outparmprobs=0i,icmp_outredirects=0i,icmp_outsrcquenchs=0i,icmp_outtimeexcds=0i,icmp_outtimestampreps=0i,icmp_outtimestamps=0i,icmpmsg_intype0=13207i,icmpmsg_intype165=1i,icmpmsg_intype3=2320i,icmpmsg_intype8=3i,icmpmsg_outtype0=3i,icmpmsg_outtype3=2351i,icmpmsg_outtype8=13213i,ip_defaultttl=64i,ip_forwarding=2i,ip_forwdatagrams=0i,ip_fragcreates=0i,ip_fragfails=0i,ip_fragoks=0i,ip_inaddrerrors=0i,ip_indelivers=6109969i,ip_indiscards=0i,ip_inhdrerrors=0i,ip_inreceives=6123485i,ip_inunknownprotos=0i,ip_outdiscards=0i,ip_outnoroutes=24i,ip_outrequests=5967253i,ip_reasmfails=0i,ip_reasmoks=0i,ip_reasmreqds=0i,ip_reasmtimeout=0i,tcp_activeopens=28502i,tcp_attemptfails=365i,tcp_currestab=397i,tcp_estabresets=171i,tcp_incsumerrors=0i,tcp_inerrs=1i,tcp_insegs=5990844i,tcp_maxconn=-1i,tcp_outrsts=2475i,tcp_outsegs=6031222i,tcp_passiveopens=31711i,tcp_retranssegs=4433i,tcp_rtoalgorithm=1i,tcp_rtomax=120000i,tcp_rtomin=200i,udp_incsumerrors=0i,udp_indatagrams=4112i,udp_inerrors=0i,udp_noports=44i,udp_outdatagrams=4126i,udp_rcvbuferrors=0i,udp_sndbuferrors=0i,udplite_incsumerrors=0i,udplite_indatagrams=0i,udplite_inerrors=0i,udplite_noports=0i,udplite_outdatagrams=0i,udplite_rcvbuferrors=0i,udplite_sndbuferrors=0i 1704442589000000000
processes,host=localhost blocked=0i,dead=0i,idle=0i,paging=0i,running=0i,sleeping=160i,stopped=0i,total=160i,total_threads=1154i,unknown=0i,zombies=0i 1704442589000000000
netstat,host=localhost tcp_close=0i,tcp_close_wait=3i,tcp_closing=0i,tcp_established=397i,tcp_fin_wait1=0i,tcp_fin_wait2=0i,tcp_last_ack=0i,tcp_listen=32i,tcp_none=9i,tcp_syn_recv=0i,tcp_syn_sent=0i,tcp_time_wait=2i,udp_socket=12i 1704442590000000000
cpu,cpu=cpu0,host=localhost usage_guest=0,usage_guest_nice=0,usage_idle=91.66666667070886,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=0,usage_steal=0,usage_system=8.33333333364913,usage_user=0 1704442590000000000
cpu,cpu=cpu1,host=localhost usage_guest=0,usage_guest_nice=0,usage_idle=79.16666666110865,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=0,usage_steal=0,usage_system=20.83333333159645,usage_user=0 1704442590000000000
cpu,cpu=cpu2,host=localhost usage_guest=0,usage_guest_nice=0,usage_idle=97.82608695459615,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=0,usage_steal=0,usage_system=2.1739130433772536,usage_user=0 1704442590000000000
cpu,cpu=cpu3,host=localhost usage_guest=0,usage_guest_nice=0,usage_idle=60.00000000291038,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=0,usage_steal=0,usage_system=35.00000000308091,usage_user=5.00000000043201 1704442590000000000
cpu,cpu=cpu-total,host=localhost usage_guest=0,usage_guest_nice=0,usage_idle=82.32044198589429,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=0,usage_steal=0,usage_system=16.574585634857467,usage_user=1.1049723756303653 1704442590000000000
[root@localhost ~]#
Please check and help me
Dears,
I already resolved this problem by changing some configuration as follows:
Thank you for your help.
