Uprading from 12.3 to 12.4 caused loss of database
Hi!
I experienced an issue when doing the upgrade from 12.3.4 to 12.4.1. Our installation is running on EC2 and deployment method is a rolling installation, so we have a mix of 12.3 and 12.4 during rollout.
As soon as the first 12.4 instance came online, I saw the following:
logger=storage.unified.migrations t=2026-03-18T09:47:46.850366791Z level=warn msg=“Failed to check if migration exists” migration=folders-dashboards error=“failed to check migration existence: Error 1146 (42S02): Table ‘grafana.unifiedstorage_migration_log’ doesn’t exist”
logger=ngalert.multiorg.alertmanager component=clustering t=2026-03-18T09:47:48.677155579Z level=warn received="unknown state key" len=33582 key=notificationlog:32
logger=live t=2026-03-18T09:51:19.286611407Z level=error msg="Error parsing channel" user=2273 client=0194f407-8c7b-4c1f-bffe-7410b11d24ae channel=32/grafana/dashboard/uid/iBYkQcC4z error="namespace does not reference a valid org ID: 32"
logger=live t=2026-03-18T09:51:19.328817743Z level=error msg="Error parsing channel" user=2232 client=7542013e-cb83-4399-8058-e6a552c20d3b channel=35/grafana/dashboard/uid/deilblmlb82yoctest error="namespace does not reference a valid org ID: 35"
The final 12.3 instance that was about to be terminated started to report encryption issues:
logger=secrets rule_uid=nA6hkx84z org_id=7 t=2026-03-18T09:58:09.79068897Z level=error msg=“Failed to decrypt secret” error=“failed to decrypt a secret encrypted with envelope encryption: envelope encryption is disabled”
logger=secrets.kvstore t=2026-03-18T09:58:09.790766408Z level=error msg=“error decrypting secret value” orgId=7 type=datasource namespace=“traffic-management” err=“failed to decrypt a secret encrypted with envelope encryption: envelope encryption is disabled”
logger=ngalert.scheduler rule_uid=nA6hkx84z org_id=7 version=10 fingerprint=12bdcfee10453167 now=2026-03-18T09:58:00Z rule_uid=nA6hkx84z org_id=7 t=2026-03-18T09:58:09.790878051Z level=error msg=“Failed to evaluate rule” attempt=2 max_attempts=3 next_attempt_in=1.63334242s error=“the result-set has errors that can be retried: failed to decrypt a secret encrypted with envelope encryption: envelope encryption is disabled”
logger=secrets rule_uid=z6ChzbUVk org_id=1 t=2026-03-18T09:58:09.794914635Z level=error msg=“Failed to decrypt secret” error=“failed to decrypt a secret encrypted with envelope encryption: envelope encryption is disabled”
I have envelope encryption disabled in both 12.3 and 12.4 so I am not sure how it decided to encrypt, furthermore there is no secret_key set in the config so not sure what it used to encrypt. This also meant rolling back was impossible as I didn’t know the encryption key so I had to restore the database from backup.
Any ideas? Annoying non-live upgraded successfully and I’ve recently tried a copy of our live DB on int and upgraded and that was successful too.
hello @michaelsawczuk please backup your database and then follow the document attached below. you can also compare the schema of the database fresh install grafana and your current database and check which tables are missing and updated (mixed). and modify according to it.
thanks
Just to provide an update, after 3 successful upgrades on non-live with a copy of the live DB, I attempted the upgrade again on live and this time it succeeded - no changes were made to our infrastructure between failure and success.
