Upgrade 6.1.6 RPM to 9.x YUM Repo
Going from 6.1.6 installed from RPM to 9.x from YUM repository. I’m sure some things will break, and that’s okay, I’ll figure that out. Just looking to understand, what all needs to migrate so that I can move us to the newest version without losing everything we’ve built. Has anyone done this before?
    v6.1.6 (commit: cf9cb45)
    Rocky Linux 8.5
    I’d like to update to a newer/latest version of Grafana without losing dashboards and playlists.
    I tried adding the YUM repo and installing the Enterprise version.
  • What happened?
    Installed successfully, started successfully but when logged in it still appears to be running 6.1.6
    Actually, I expected to get some kind of error about config files not matching, or something indicating that the new version couldn’t grab port 3000 or something like that. But it would have been really awesome if it just worked.
    Irrelevant.
    Nothing interesting.
    Just the standard installation instructions from grafana.com
