Grafana 9 in Docker on Linux
- What are you trying to achieve?
I had dashboards running under Grafana 8. Upgrading to Grafana 9 made the time series panel to sometimes display the wrong data.
- How are you trying to achieve it?
Prometheus, Thanos, Grafana 9
- What happened?
Pressing refresh gives the expected dashboard
Dashboards to display the correct data
- Can you copy/paste the configuration(s) that you are having problems with?
"annotations": {
"list": [
"builtIn": 1,
"datasource": {
"type": "datasource",
"uid": "grafana"
"enable": true,
"hide": true,
"iconColor": "rgba(0, 211, 255, 1)",
"name": "Annotations & Alerts",
"target": {
"limit": 100,
"matchAny": false,
"tags": [],
"type": "dashboard"
"type": "dashboard"
"editable": true,
"fiscalYearStartMonth": 0,
"graphTooltip": 0,
"id": 18,
"links": [],
"liveNow": false,
"panels": [
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": {
"type": "prometheus",
"uid": "P5DCFC7561CCDE821"
"fieldConfig": {
"defaults": {
"unit": "bps"
"overrides": [
"matcher": {
"id": "byName",
"options": "Transmit vmx0"
"properties": [
"id": "displayName",
"value": "Transmit LAN"
"id": "links"
"matcher": {
"id": "byName",
"options": "Transmit vio0"
"properties": [
"matcher": {
"id": "byName",
"options": "Receive vmx0"
"properties": [
"value": "Receive LAN"
"matcher": {
"id": "byName",
"options": "Receive vio0"
"properties": [
"matcher": {
"id": "byName",
"options": "Transmit vmx1"
"properties": [
"value": "Transmit DMZ"
"matcher": {
"id": "byName",
"options": "Transmit vio4"
"properties": [
"matcher": {
"id": "byName",
"options": "Receive vmx1"
"properties": [
"value": "Receive DMZ"
"matcher": {
"id": "byName",
"options": "Receive vio4"
"properties": [
"matcher": {
"id": "byName",
"options": "Transmit vmx2"
"properties": [
"value": "Transmit WAN"
"matcher": {
"id": "byName",
"options": "Transmit vio1"
"properties": [
"matcher": {
"id": "byName",
"options": "Receive vmx2"
"properties": [
"value": "Receive WAN"
"matcher": {
"id": "byName",
"options": "Receive vio1"
"properties": [
"matcher": {
"id": "byName",
"options": "Transmit vmx3"
"properties": [
"value": "Transmit Guest"
"matcher": {
"id": "byName",
"options": "Transmit vio2"
"properties": [
"matcher": {
"id": "byName",
"options": "Receive vmx3"
"properties": [
"value": "Receive Guest"
"matcher": {
"id": "byName",
"options": "Receive vio2"
"properties": [
"matcher": {
"id": "byName",
"options": "Transmit vmx4"
"properties": [
"value": "Transmit DMZ2"
"matcher": {
"id": "byName",
"options": "Transmit vio5"
"properties": [
"matcher": {
"id": "byName",
"options": "Receive vmx4"
"properties": [
"value": "Receive DMZ2"
"matcher": {
"id": "byName",
"options": "Receive vio5"
"properties": [
"matcher": {
"id": "byName",
"options": "Transmit vmx5"
"properties": [
"value": "Transmit IoT"
"matcher": {
"id": "byName",
"options": "Transmit vio3"
"properties": [
"matcher": {
"id": "byName",
"options": "Receive vmx5"
"properties": [
"value": "Receive IoT"
"matcher": {
"id": "byName",
"options": "Receive vio3"
"properties": [
"fill": 2,
"fillGradient": 0,
"gridPos": {
"h": 10,
"w": 19,
"x": 0,
"y": 0
"hiddenSeries": false,
"id": 2,
"legend": {
"alignAsTable": true,
"avg": true,
"current": false,
"max": false,
"min": false,
"rightSide": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 1,
"nullPointMode": "null",
"options": {
"alertThreshold": true
"percentage": false,
"pluginVersion": "9.1.0",
"pointradius": 2,
"points": false,
"renderer": "flot",
"seriesOverrides": [
"$$hashKey": "object:102",
"alias": "/LAN/",
"color": "#73BF69"
"$$hashKey": "object:103",
"alias": "/DMZ$/",
"color": "#B877D9"
"$$hashKey": "object:104",
"alias": "/WAN/",
"color": "#FADE2A"
"$$hashKey": "object:105",
"alias": "/IoT/",
"color": "#5794F2"
"$$hashKey": "object:106",
"alias": "/Guest/",
"color": "#F2495C"
"$$hashKey": "object:151",
"alias": "/Transmit/",
"transform": "negative-Y"
"$$hashKey": "object:383",
"alias": "/DMZ2/",
"color": "#8F3BB8"
"spaceLength": 10,
"stack": false,
"steppedLine": false,
"targets": [
"datasource": {
"expr": "irate(node_network_receive_bytes_total{instance=\"fw.hemma:9100\",job=\"node\",device=~\"vmx.*|vio.*\"}[$__rate_interval])*8",
"interval": "",
"legendFormat": "Receive {{ device }}",
"refId": "B"
"datasource": {
"expr": "irate(node_network_transmit_bytes_total{instance=\"fw.hemma:9100\",job=\"node\",device=~\"vmx.*|vio.*\"}[$__rate_interval])*8",
"interval": "",
"legendFormat": "Transmit {{ device }}",
"refId": "A"
"thresholds": [],
"timeRegions": [],
"title": "Firewall network",
"tooltip": {
"shared": true,
"sort": 2,
"value_type": "individual"
"transformations": [],
"type": "graph",
"xaxis": {
"mode": "time",
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:137",
"format": "bps",
"label": "Network usage, out (-) / in (+)",
"logBase": 1,
"show": true
"$$hashKey": "object:138",
"format": "short",
"logBase": 1,
"show": false
"yaxis": {
"align": false
"datasource": {
"fieldConfig": {
"defaults": {
"color": {
"mode": "thresholds"
"mappings": [],
"max": 500000000,
"min": 0,
"thresholds": {
"mode": "percentage",
"steps": [
"color": "red",
"value": null
"color": "green",
"value": 80
"unit": "decbits"
"overrides": []
"gridPos": {
"h": 7,
"w": 5,
"x": 19,
"y": 0
"id": 14,
"maxDataPoints": 1,
"options": {
"orientation": "auto",
"reduceOptions": {
"calcs": [
"mean"
"fields": "",
"values": true
"showThresholdLabels": false,
"showThresholdMarkers": true,
"text": {}
"targets": [
"expr": "avg_over_time(download_speed_bps[$__interval])",
"format": "time_series",
"instant": true,
"interval": "",
"legendFormat": "Download",
"refId": "B"
"expr": "avg_over_time(upload_speed_bps[$__interval])",
"instant": true,
"interval": "",
"legendFormat": "Upload",
"refId": "A"
"title": "Internet speedtest",
"type": "gauge"
"datasource": {
"fieldConfig": {
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 15
"unit": "ms"
"overrides": []
"gridPos": {
"h": 3,
"w": 5,
"x": 19,
"y": 7
"id": 13,
"options": {
"colorMode": "value",
"graphMode": "area",
"justifyMode": "auto",
"reduceOptions": {
"calcs": [
"mean"
"fields": "",
"values": false
"text": {},
"textMode": "auto"
"targets": [
"expr": "avg_over_time(ping_ms[$__interval])",
"instant": false,
"interval": "",
"legendFormat": "Ping",
"refId": "A"
"title": "Ping",
"type": "stat"
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": {
"fill": 2,
"fillGradient": 0,
"gridPos": {
"h": 8,
"w": 12,
"x": 0,
"y": 10
"id": 4,
"legend": {
"alignAsTable": false,
"avg": false,
"current": false,
"max": false,
"min": false,
"show": true,
"total": false,
"values": false
"lines": true,
"linewidth": 1,
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"$$hashKey": "object:280",
"alias": "/Hall uppe/",
"color": "#73BF69"
"$$hashKey": "object:281",
"alias": "/Kontor/",
"color": "#FADE2A"
"$$hashKey": "object:282",
"alias": "/Tvättstuga/",
"color": "#B877D9"
"$$hashKey": "object:283",
"alias": "/Vardagsrummet/",
"color": "#5794F2"
"$$hashKey": "object:322",
"spaceLength": 10,
"stack": false,
"targets": [
"expr": "unifipoller_device_radio_channel_utilization_receive_ratio{radio=\"ng\"}",
"interval": "",
"legendFormat": "Receive {{name}}",
"refId": "B"
"expr": "unifipoller_device_radio_channel_utilization_transmit_ratio{radio=\"ng\"}",
"interval": "",
"legendFormat": "Transmit {{name}}",
"refId": "A"
"thresholds": [],
"timeRegions": [],
"title": "WiFi usage 2G",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"mode": "time",
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:308",
"format": "percentunit",
"label": "WiFi 2g usage, from AP (-) / to AP (+)",
"logBase": 1,
"show": true
"$$hashKey": "object:309",
"format": "short",
"logBase": 1,
"show": false
"yaxis": {
"align": false
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": {
"fill": 2,
"fillGradient": 0,
"gridPos": {
"h": 8,
"w": 12,
"x": 12,
"y": 10
"id": 5,
"legend": {
"avg": false,
"current": false,
"max": false,
"min": false,
"show": true,
"total": false,
"values": false
"lines": true,
"linewidth": 1,
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"$$hashKey": "object:445",
"color": "#73BF69"
"$$hashKey": "object:446",
"color": "#FADE2A"
"$$hashKey": "object:447",
"color": "#B877D9"
"$$hashKey": "object:448",
"color": "#5794F2"
"$$hashKey": "object:487",
"spaceLength": 10,
"stack": false,
"targets": [
"expr": "unifipoller_device_radio_channel_utilization_receive_ratio{radio=\"na\"}",
"interval": "",
"refId": "B"
"expr": "unifipoller_device_radio_channel_utilization_transmit_ratio{radio=\"na\"}",
"interval": "",
"refId": "A"
"thresholds": [],
"timeRegions": [],
"title": "WiFi usage 5G",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"mode": "time",
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:473",
"label": "WiFi 5g usage, from AP (-) / to AP (+)",
"logBase": 1,
"show": true
"$$hashKey": "object:474",
"format": "short",
"logBase": 1,
"show": false
"yaxis": {
"align": false
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": {
"fill": 2,
"fillGradient": 0,
"gridPos": {
"h": 6,
"w": 12,
"x": 0,
"y": 18
"id": 8,
"legend": {
"avg": false,
"current": false,
"max": false,
"min": false,
"show": true,
"total": false,
"values": false
"lines": true,
"linewidth": 1,
"options": {
"pointradius": 2,
"points": false,
"renderer": "flot",
"seriesOverrides": [],
"spaceLength": 10,
"stack": true,
"targets": [
"expr": "count without (mac) (group by(mac, network) (rate(unifipoller_client_satisfaction_ratio[$__rate_interval])))",
"interval": "",
"intervalFactor": 10,
"legendFormat": "{{network}}",
"refId": "A"
"thresholds": [],
"timeRegions": [],
"title": "# clients",
"tooltip": {
"shared": true,
"sort": 0,
"id": "filterFieldsByName",
"options": {
"include": {
"names": [
"Time",
"GUEST",
"IoT",
"LAN"
"type": "graph",
"xaxis": {
"mode": "time",
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:610",
"format": "short",
"logBase": 1,
"show": true
"$$hashKey": "object:611",
"format": "short",
"logBase": 1,
"show": false
"yaxis": {
"align": false
"datasource": {
"fieldConfig": {
"defaults": {
"custom": {
"align": "auto",
"displayMode": "auto",
"filterable": false,
"inspect": false
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"unit": "bps"
"overrides": [
"matcher": {
"id": "byName",
"options": "sw_port"
"properties": [
"id": "unit",
"value": "string"
"gridPos": {
"h": 6,
"w": 6,
"x": 12,
"y": 18
"id": 9,
"maxDataPoints": 1,
"options": {
"footer": {
"fields": "",
"reducer": [
"sum"
"show": false
"showHeader": true
"targets": [
"expr": "topk(4, sort_desc(sum by (name) (rate(unifipoller_client_receive_bytes_total[$__range] )))) * 8",
"format": "table",
"instant": true,
"interval": "",
"legendFormat": "",
"refId": "A"
"title": "Top 4 transmitting clients",
"id": "organize",
"options": {
"excludeByName": {
"Time": true,
"ap_name": true,
"cluster": true,
"instance": true,
"ip": true,
"job": true,
"mac": true,
"network": true,
"oui": true,
"site_name": true,
"source": true,
"sw_name": true,
"sw_port": true,
"vlan": true,
"wired": true
"indexByName": {},
"renameByName": {}
"type": "table"
"datasource": {
"fieldConfig": {
"defaults": {
"custom": {
"align": "auto",
"inspect": false
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"unit": "bps"
"overrides": [
"matcher": {
"id": "byName",
"properties": [
"id": "unit",
"value": "string"
"gridPos": {
"h": 6,
"w": 6,
"x": 18,
"y": 18
"id": 10,
"maxDataPoints": 1,
"options": {
"footer": {
"fields": "",
"reducer": [
"sum"
"show": false
"showHeader": true
"targets": [
"expr": "topk(4, sort_desc(sum by (name) (rate(unifipoller_client_transmit_bytes_total[$__range] )))) * 8",
"format": "table",
"instant": true,
"interval": "",
"legendFormat": "",
"refId": "A"
"title": "Top 4 receiving clients",
"id": "organize",
"options": {
"excludeByName": {
"Time": true,
"ap_name": true,
"cluster": true,
"instance": true,
"ip": true,
"job": true,
"mac": true,
"network": true,
"oui": true,
"site_name": true,
"source": true,
"sw_name": true,
"sw_port": true,
"vlan": true,
"wired": true
"indexByName": {},
"renameByName": {}
"type": "table"
"refresh": "",
"schemaVersion": 37,
"style": "dark",
"tags": [],
"templating": {
"list": []
"time": {
"from": "now-6h",
"to": "now"
"timepicker": {},
"timezone": "",
"title": "Network",
"uid": "bZN9AvJMk",
"version": 33,
"weekStart": ""
