Update multiple organizations without changing variables
Hello everyone,
I am currently managing a dozen of organization in which we deployed a couple of dashboards in a dedicated folder which is named the same between those organizations.
These dashboards are identical between the organizations (even the uids) at the exceptions of the variables and the data source. Is there a way to copy the updated dashboards from the development organization in the other ones without having to manually correct these variables and data source in each organization?
Thanks, that solved my datasource problem, and for the constant variable I am lucky because it is the ${Datasource:text}
