Unsupported data sources for public dashboard using InfluxDB
When I use a single panel dashboard with a Time Series graph and share it as public the warning does not appear, but when I add an extra panel with exactly the same data as in the first panel when I try to share as public the warning now appears:
There are data sources in this dashboard that are unsupported for public dashboards. Panels that use these data sources may not function properly: .
The same thing happens with a dashboard with Gauges, if I use a single panel the warning does not appear, but if I add an extra panel with the same gauges using the same configurations as in the first panel now the warning appears again. I don’t see where the problem is since InfluxDB is supported for public sharing.
There is a similiar topic with no solution.
What could be generating the warning?
