We have been using the following plugin PRTG plugin for Grafana | Grafana Labs since Grafana 7 but today when I’m trying out Grafana 8 with Docker Compose, the plugin no longer works.
I understand that the plugin is unsigned and have not been maintained by the creator for some time, but we’d love to continue its use. To my understanding, we should be able to allow loading unsigned plugins.
our docker compose looks like this
grafana:
container_name: grafana
restart: always
image: grafana/grafana:8.0.5
labels:
- "traefik.backend=grafana"
- "traefik.docker.network=compose_frontend"
- "traefik.port=3000"
- "traefik.frontend.entryPoints=http,https"
- "traefik.frontend.rule=Host:grafana.foo.net"
environment:
- "GF_ALLOW_LOADING_UNSIGNED_PLUGINS=jasonlashua-prtg-datasource"
- "GF_INSTALL_PLUGINS=grafana-clock-panel,grafana-piechart-panel"
- "GR_PATHS_PLUGINS=/var/lib/grafana/plugins"
- "GF_SERVER_ROOT_URL=https://grafana.foo.net"
volumes:
- ./grafana/grafana.db:/var/lib/grafana/grafana.db
- ./grafana/plugins:/var/lib/grafana/plugins
However whenever I run docker, I keep getting the following error
grafana | t=2021-07-14T02:18:55+0000 lvl=warn msg="Some plugin scanning errors were found" logger=plugins errors="plugin with ID 'jasonlashua-prtg-datasource' already exists in '/var/lib/grafana/plugins/jasonlashua-prtg-datasource', plugin 'jasonlashua-prtg-datasource' is unsigned"
in Grafana’s plugin section I got this message
Would the community be able to help if case i’m missing something?
