Hi everyone!
Several days that I struggle with this problem . I’m a Grafana total newbie :-D!
I’d like to run unit tests with JEST and ENZYME in my custom plugin, installed with
npx @grafana/toolkit plugin:create my-grafana-plugin
I’ve followed instructions there @grafana/toolkit - npm about testing plugin, created /config/jest-setup.ts with code provided.
I didn’t change jest.config.js as recommended.
Here’s my simple test code :
import React from 'react';
import { FFTPage } from './FFTPage';
import {SelectSession} from './SelectSession/SelectSession'
import { shallow } from 'enzyme';
describe('FFTPage', () => {
it('contains SelectSession', () => {
const wrapper = shallow(<FFTPage />)
expect(wrapper).toContain(<SelectSession />)
Here’s the package.json in plugin root :
"name": "custom-plugin",
"version": "1.0.0",
"description": "FTT Zoom",
"scripts": {
"build": "grafana-toolkit plugin:build",
"test": "grafana-toolkit plugin:test",
"dev": "grafana-toolkit plugin:dev",
"watch": "grafana-toolkit plugin:dev --watch",
"format": "prettier --write \"{,!(node_modules|dist|typedoc|docs)/**/}*.{ts,tsx}\""
"repository": "github:grafana/simple-react-panel",
"author": "Grafana",
"license": "Apache-2.0",
"bugs": {
"url": "https://github.com/grafana/simple-react-panel/issues",
"email": "plugins@grafana.com"
"devDependencies": {
"@grafana/data": "7.0.0",
"@grafana/toolkit": "7.0.0",
"@grafana/ui": "^7.0.0",
"emotion": "10.0.27"
"engines": {
"node": ">=12 <13"
"dependencies": {
"plotly.js": "^1.58.4",
"react-plotly.js": "^2.5.1"
After running test, this error is thrown :
Test suite failed to run
Jest encountered an unexpected token
This usually means that you are trying to import a file which Jest cannot parse, e.g. it's not plain JavaScript.
By default, if Jest sees a Babel config, it will use that to transform your files, ignoring "node_modules".
Here's what you can do:
• To have some of your "node_modules" files transformed, you can specify a custom "transformIgnorePatterns" in your config.
• If you need a custom transformation specify a "transform" option in your config.
• If you simply want to mock your non-JS modules (e.g. binary assets) you can stub them out with the "moduleNameMapper" config option.
Details:
/home/sandy/asystom_grafana/grafana-7.1.5/node_modules/@iconscout/react-unicons/index.js:1
({“Object.”:function(module,exports,require,__dirname,__filename,global,jest){export { default as Uil0Plus } from ‘./icons/uil-0-plus’;
Do I need to configure a babel file?
Any help will be SO appreciated <3 thanks !
Sandy.
