[unified_alerts] Granfana 8 - Notification Policies based on Prometheus Alerts
Is it possible to get notified based on Prometheus alerts?
We have a Prometheus configured with some alerts, and we have Grafana [v8.2.5 (b57a137acd)] with the new alerting (unified_alert) enabled.
After adding the Prometheus datasource, we can see the alerts in the Alert dashboard. We also configure the contact point and the notification policies based on this alerts, but we are never notified based on the Prometheus alerts (if we create the alert manually, everything works as it should).
So my question is: is it possible to get notified based on the Prometheus alerts (out-of-the-box) or only if I create the alert manually?
Thank you very much in advance.
Grafana v8.2.5 (b57a137acd), running the Docker image at grafana/grafana.
I’m trying to get notified based on Prometheus alerts
By adding the Prometheus data source, I can see all the alerts in the the Alert dashboard, however the notification policy is not triggered when there is a matching alert.
Everything works as supposed when creating the alert manually.
  • What happened?
    Notification policies are not triggered based on Prometheus alerts.
    I expect to not need to recreate the alerts if Prometheus already provide it to Grafana and to get notified if the notification policy matches the alert.
Which configuration would be interesting?
No errors in the Grafana UI.
Hi, do you have any news on this matter? Did you find a workaround? I am having the exact same issue.
Nothing so far, I’ve also pinged the community and the dev team in the slack channel, but nothing so far.
We haven’t found a solution yet.
I ended up going with AlertManager on its own. Too bad this use case is not supported. I will check again in a few releases.
Hi - is there any issue posted on this, on the github tracker?
I doubt they track issues on here :wink:
Hi, is there any update for this?
github maybe?
