Understanding rate in constant-arrival-rate executor
I’m using constant-arrival-rate executor and running 1170 req/sec.
  executor: 'constant-arrival-rate',
  duration: '1800s',
  rate: 1170,
  timeUnit: '1s',
  preAllocatedVUs: 50,
  maxVUs: 3500
If you see the summary below, the http_reqs shows as “104944 169.239844/s”.
But being, I’m using constant-arrival-rate, I expect, the http_reqs should be near to 1170 (that I’ve set in the above config)
execution: local
     script: test.js
     output: -
  scenarios: (100.00%) 1 scenario, 3500 max VUs, 10m30s max duration (incl. graceful stop):
           * testCall: 1170.00 iterations/s for 10m0s (maxVUs: 50-3500, gracefulStop: 30s)
WARN[0011] Insufficient VUs, reached 3500 active VUs and cannot initialize more  executor=constant-arrival-rate scenario=testCall
INFO[0620] [k6-reporter v2.3.0] Generating HTML summary report  source=console
     ✓ status is 200
     █ setup
     checks.........................: 100.00% ✓ 104944     ✗ 0
     data_received..................: 161 MB  259 kB/s
     data_sent......................: 7.1 MB  11 kB/s
     dropped_iterations.............: 597056  962.853179/s
     http_req_blocked...............: avg=6.58ms  min=141ns   med=285ns   max=288.55ms p(90)=357ns   p(95)=405ns
     http_req_connecting............: avg=2.18ms  min=0s      med=0s      max=118.22ms p(90)=0s      p(95)=0s
     http_req_duration..............: avg=20.21s  min=20.06s  med=20.11s  max=24.4s    p(90)=20.24s  p(95)=20.8s
       { expected_response:true }...: avg=20.21s  min=20.06s  med=20.11s  max=24.4s    p(90)=20.24s  p(95)=20.8s
     http_req_failed................: 0.00%   ✓ 0          ✗ 104944
     http_req_receiving.............: avg=34.89µs min=12.57µs med=29.35µs max=396.95ms p(90)=38.43µs p(95)=41.53µs
     http_req_sending...............: avg=23.09µs min=10.88µs med=21.01µs max=783.62µs p(90)=27.6µs  p(95)=33.58µs
     http_req_tls_handshaking.......: avg=4.37ms  min=0s      med=0s      max=170.95ms p(90)=0s      p(95)=0s
     http_req_waiting...............: avg=20.21s  min=20.06s  med=20.11s  max=24.4s    p(90)=20.24s  p(95)=20.8s
     http_reqs......................: 104944  169.239844/s
     iteration_duration.............: avg=20.22s  min=11.45µs med=20.11s  max=24.6s    p(90)=20.24s  p(95)=20.86s
     iterations.....................: 104944  169.239844/s
     vus............................: 35      min=35       max=3500
     vus_max........................: 3500    min=359      max=3500
running (10m20.1s), 0000/3500 VUs, 104944 complete and 0 interrupted iterations
testCall ✓ [======================================] 0000/3500 VUs  10m0s  1170.00 iters/s
Also, in addition to this, I’ve set 3500 as VUs & and rps as 1170, so is that every VU will invoke 1170/sec (i.e. 3500x1170 = 4,095,000 request). I’m pretty much sure this should not be case as summary has different numbers. How does VUs works in this executor and with respect to constant requests?
Please help me here.
Hi @ampk6 There is warning in console show number of VUs allocated was not suffient to reach desired RPS increases number of preAllocatedVUs.
Hi @ampk6
As @Elibarick mentioned, the key is in the warning.
Your test needs more virtual users to run the load. I would recommend, to be optimal, using preAllocatedVUs: 3500 so the test already has the VUs available at the start.
If that is not enough to run the required load (1170 requests per second during 1800s), you will need to increase the number of preAllocatedVUs. Other tips for running large tests:
I hope this helps.
Cheers!
Thanks. @Elibarick @eyeveebe. I rechecked my graph and the request count are near to equal.
Also, in above case, 3500 VUs will randomly utilized through out 1800s. Its not like, each VU will invoke 1170 request every second for the duration of 1800sec.
Please confirm my understanding ?
Also, what does the below 2 line indicates in summary with respect to the min/max for vus & vus_max
vus…: 35 min=35 max=3500
vus_max…: 3500 min=359 max=3500
In addition to this, why the summary dosnot show the start/end date time? (Is it possible to show as per timezone ?)
