Understanding basic auth and Loki
I am trying to set up Loki and enable authentication and I am confused by conflicting information.
When configuring a Data Source in Loki, there is the option to enable Authentication, either basic auth or OAuth2.0 token pass-through.
However, at Authentication | Grafana Loki documentation, it says “Grafana Loki does not come with any included authentication layer.” If that is true, what’s the meaning of the auth options in the data source? The documentation goes on to show use of the basic auth or OAuth in configuration examples, as seen at Configure the Loki data source | Grafana documentation.
I do not need multi-tenant mode. All I want to do is add a protection layer over the ability for my remote promtail agents to reach the Loki endpoint.
I’m happy enough to just use basic_auth on my Nginx reverse proxy that sits in front of Loki. But if so, I don’t understand the point of the auth options for the Data Source. Do I need both (and make sure Loki recognizes the same password as the one I configure in Nginx’s basic auth file), or just one or the other?
What is the conflict?
Loki allows you to put what you want in front of Loki for auth, e.g. you are familiar with nginx basic auth, so nginx can be your auth layer. More advanced users use OAuth for authentication and authorization, so they will deploy some OAuth proxy.
Every of these users want to have just copy&paste example in the doc, so it’s there. Use example for your use case.
Thanks jangaraj. What I am confused about is, what is the purpose of setting auth (basic or OAuth) at the Loki ‘data source’ layer, if you’ve already set the auth at the Nginx layer?
If “Grafana Loki does not come with any included authentication layer”, why are there authentication options when configuring the Data Source?
Is it just for when the Grafana interface would need to traverse the Nginx proxy to reach the Loki endpoint, as opposed to via localhost?
Because Grafana is connecting to Loki and if Loki has some auth layer, you must be able to set that auth in the Grafana Loki datasource configuration. Otherwise, Grafana won’t receive any suitable response from Loki.
Thank you @jangaraj ! I finally understand.
So in my case, Grafana and Loki are on the same network defined in the same Docker Compose file. This means that for a Loki Data source, I can leave it as ‘No authentication’ and have it connect to http://loki:3100 (bypassing the Nginx reverse proxy altogether).
Meanwhile, my remote Promtail agents will traverse the Nginx reverse proxy and so will use the basic auth.
Makes sense now. Thanks!
So if I am using for example FluentBit ( on EC2 instances ) to send the logs to Loki ,with basic authentication , I have to put the username and password in cleartext in the FluentBit config file , right ?
Your question is about fluentbit, not Loki. Fluentbit can use environment variable, so you don’t need to put password in configuration file, see Environment variables | Fluent Bit: Official Manual
If you wish to have further discussions on this topic I’d recommend you to create a new thread.
