I set up an otel collector, tempo and grafana in my docker. I dont see any traces in grafana. I dont see any logs in my otel collector either so not sure if my traces are being received in otel collector. Can someone please help me with my docker compose setup if im missing something? My containers are able to startup fine.
The reason i set the port to 4319 in tempo is because i was getting an error in my tempo container saying 4317 is already in use, presumably by my otel-collector
otel-collector.yaml:
receivers:
otlp:
protocols:
grpc:
endpoint: 0.0.0.0:4317
http:
endpoint: 0.0.0.0:4318
exporters:
otlp:
endpoint: tempo:4319 # Tempo container name and gRPC port
tls:
insecure: true
debug:
verbosity: detailed # Use 'normal' or 'detailed'
service:
pipelines:
traces:
receivers: [otlp]
exporters: [otlp, debug]
tempo.yaml:
auth_enabled: false
server:
http_listen_port: 3200
grpc_listen_port: 4319
distributor:
receivers:
otlp:
protocols:
grpc:
http:
ingester:
trace_idle_period: 10s
max_block_duration: 5m
compactor:
compaction:
block_retention: 1h
storage:
trace:
backend: local
local:
path: /tmp/tempo/traces
docker-compose:
otel-collector:
image: otel/opentelemetry-collector-contrib:latest
command: ["--config=/etc/otel-collector-config.yaml"]
volumes:
- ./otel-collector-config.yaml:/etc/otel-collector-config.yaml
depends_on:
- tempo
tempo:
image: grafana/tempo:latest
command: ["-config.file=/etc/tempo.yaml"]
volumes:
- ./tempo-config.yaml:/etc/tempo.yaml
ports:
- "4318:4318" # Exposing the new port (4318)
grafana:
image: grafana/grafana:latest
ports:
- "3000:3000"
environment:
- GF_SECURITY_ADMIN_PASSWORD=admin
depends_on:
- tempo
