10.2 -
Opening Grafana on localhost:3000 -
Using browser -
What happened?
Page doesnt open -
[server]
# Protocol (http, https, h2, socket)
protocol = http
# The ip address to bind to, empty will bind to all interfaces
http_addr =
# The http port to use
http_port = 3000
# The public facing domain name used to access grafana from a browser
domain = localhost
I was able to open the Grafana page on localhost:3000 but all of a sudden it has stopped working, defaults.ini file still states localhost and port number but my browser no longer open the Grafana page.
Thanks
