v10.3.4, Linux
We are working on allowing users to access Grafana by port-forwarding from Kubernetes as admin.
I’m running Grafana helm chart version 7.3.9 (latest). I’m running Grafana through terraform and attempting to access by port-forwarding from local command line, eg: kubectl port-forward svc/grafana 3001:80 and logging into localhost:3001 locally.
Some things we’ve tried:
- I’ve tried running this on Grafana 10.3.4 and 10.2.2.
- I also tried to run this with Chart version 6.56.1 (we updated the chart to confirm the chart version wasn’t the issue here).
- I am able to access dashboards/alerts/metrics etc. by setting anonymous auth, but when I set anonymous auth, attempting to log in with username/password still doesn’t work.
What happened?
I’m getting a user/pass failed on attempting to log in.
I expect to be able to login as admin with admin/password credentials.
Helm chart:
image:
repository: grafana/grafana
tag: 10.3.4
adminPassword: password
datasources:
datasources.yaml:
apiVersion: 1
datasources: []
grafana.ini:
log:
level: debug
users:
auto_assign_org_role: Viewer
persistence:
enabled: true
serviceMonitor:
enabled: true
sidecar:
alerts:
enabled: true
logLevel: DEBUG
useStatefulSet: true
This is the grafana.ini from within the pod:
[analytics]
check_for_updates = true
[grafana_net]
url = https://grafana.net
[log]
level = debug
mode = console
[paths]
data = /var/lib/grafana/
logs = /var/log/grafana
plugins = /var/lib/grafana/plugins
provisioning = /etc/grafana/provisioning
[server]
domain = ''
[users]
auto_assign_org_role = Viewer
When I SSH into the relevant pod, I see the env variables GF_SECURITY_ADMIN_PASSWORD=password and GF_SECURITY_ADMIN_USER=admin, so admin/password should be the correct credentials here.
I see the following logs in Grafana:
logger=authn.password t=2024-04-19T22:10:51.793268812Z level=debug msg="Failed to authenticate password identity" client=grafana error="[password-auth.invalid] invalid password"
logger=authn.service t=2024-04-19T22:10:51.799198887Z level=info msg="Failed to authenticate request" client=auth.client.basic error="[password-auth.failed] failed to authenticate identity: [password-auth.invalid] invalid password"
logger=context userId=0 orgId=0 uname= t=2024-04-19T22:10:51.799254052Z level=info msg= error="[password-auth.failed] failed to authenticate identity: [password-auth.invalid] invalid password" remote_addr=[::1] traceID=
logger=context userId=0 orgId=0 uname= t=2024-04-19T22:10:51.799295361Z level=info msg="Request Completed" method=POST path=/api/admin/provisioning/alerting/reload status=401 remote_addr=[::1] time_ms=18 duration=18.792781ms size=121 referer= handler=/api/admin/provisioning/alerting/reload
The Alerts sidecar yields a similar error:
{"time": "2024-04-19T22:10:51.778147+00:00", "taskName": null, "msg": "Writing /etc/grafana/provisioning/alerting/alerts.yaml (ascii)", "level": "INFO"}
{"time": "2024-04-19T22:10:51.799953+00:00", "taskName": null, "msg": "POST request sent to http://localhost:3000/api/admin/provisioning/alerting/reload. Response: 401 Unauthorized {\"extra\":null,\"message\":\"Invalid username or password\",\"messageId\":\"password-auth.failed\",\"statusCode\":401,\"traceID\":\"\"}\n", "level": "DEBUG"}
I checked Grafana auth docs.
