I am using grafana 11.5 on linux system -
I need to login in grafana with admin role via keycloak. -
I have configured the grafana ini file from the documentation and other available sources. Also I have added proper roles in keyclock user and same is available in request payload. -
What happened?
After signing up/logging in via Keycloak, the user is assigned the “Viewer” role. Even after setting therole_attribute_path
field to the hardcoded “Admin” value, the user is still assigned the “Viewer” role. -
I want user signup/logged in with Admin role. -
Below is the grafana.ini file:
[auth.generic_oauth]
enabled = true
name = keycloak
allow_sign_up = true
auto_login = false
use_pkce = true
use_refresh_token = true
tls_skip_verify_insecure = true
client_id =
client_secret = <valid_client_secret>
auth_url = https://<keycloak_domain>/auth/realms/emrealm/protocol/openid-connect/auth
token_url = https://<keycloak_domain>/auth/realms/emrealm/protocol/openid-connect/token
api_url = https://<keycloak_domain>/auth/realms/emrealm/protocol/openid-connect/userinfo
redirect_uri = http://<grafana_domain>/login/generic_oauth
role_attribute_path = contains(realm_access.roles[], ‘Admin’) && ‘Admin’ || contains(realm_access.roles[], ‘EM_admin’) && ‘Editor’ || ‘Viewer’
auto_assign_org_role = false
skip_org_role_sync = true
allow_assign_grafana_admin = true
email_attribute_path = email
login_attribute_path = username
name_attribute_path = name
role_attribute_strict = false
org_attribute_path = roles
org_mapping = ‘Admin’
role_mapping = {“Admin”: “Admin”, “Editor”: “Editor”, “default”: “Editor”}
scopes = openid email profile roles
signout_redirect_url = https://<keycloak_domain>/auth/realms/emrealm/protocol/openid-connect/logout?post_logout_redirect_uri=http://<grafana_domain>/login
Below is the request payload:
“realm_access”: {
“roles”: [
“default-roles-emrealm”,
“offline_access”,
“admin”,
“uma_authorization”,
“EM_admin”,
“Admin”
“roles”: [
“offline_access”,
“admin”,
“EM_admin”,
“Admin”
No errors are found in the Grafana UI or the log files. -
Configure Generic OAuth authentication | Grafana documentation
