Unable to generate service graph
I am collecting traces from grafana through alloy and tempo. Traces can be visualized and also i can see node graph but when go to service graph it is showing no service graph data found
Here is my tempo configuration
stream_over_http_enabled: true
server:
http_listen_port: 3200
log_level: info
query_frontend:
search:
duration_slo: 5s
throughput_bytes_slo: 1.073741824e+09
metadata_slo:
duration_slo: 5s
trace_by_id:
duration_slo: 5s
distributor:
receivers:
otlp:
protocols:
grpc:
endpoint: “ip:4317”
metrics_generator:
registry:
external_labels:
source: tempo
cluster: docker-compose
processor:
service_graphs:
wait: 30s
max_items: 10000
workers: 10
dimensions:
storage:
path: /mnt/tempodata/generator/wal
remote_write:
- url: https://ip:9090/api/v1/write
send_exemplars: true
traces_storage:
path: /mnt/tempodata/generator/traces
storage:
trace:
backend: local # backend configuration to use
wal:
path: /mnt/tempodata/wal # where to store the wal locally
local:
path: /mnt/tempodata/blocks
overrides:
defaults:
metrics_generator:
processors: [service-graphs, span-metrics, local-blocks] # enables metrics generator
generate_native_histograms: both
