Using the CloudWatch plugin, I’m able to pull metrics from the AWS/MediaLive and AWS/CloudFront namespaces, however there is no AWS/MediaPackage namespace listed in the drop down.
I’ve selected the correct region, and if I put double quotes around “AWS/MediaPackage”, then the correct data populates for the other dropdowns (dimensions, stats, etc). But when I select all of the fields that I want to view, there are “no data points”.
When I use the aws cli, I can pull the metrics manually, the data does exist.
Ideas?
