Unable to convert har file into test generator/js file
Hello Team,
We are using k6 studio for browser recording. But in our company, many teams are using different tools and especially chrome web developer for recording the UI functionality. It would be great if we can import such har files into k6 studio and able to convert into .js file. I look forward to hearing from you..
Thank you..
Hi and welcome!
When you create a new Generator in the top right you have the option to import an external HAR file by pressing the + symbol:
Could you give more details about the issue if it’s happening in a further step?
Thanks for your response. When i import the har file, it gets listed under Recordings but when i select that file it shows “The Recording is empty” and doesn’t show any events which available in har file
I see, could you share the HAR file to help with debugging with this issue ?
Please do remove any secret/confidential information from it and also feel free if possible to send it directly via a direct message on here!
