I’m having an issue when trying to extract measurement data from the HTMLCtrl panel object. I have 2 different data sources: SQL Server and OPC UA. Normally, if I query each data source on its own, I can read the data from ctrl.data array. But it isn’t working with Mixed data sources.
v9.0.2 - Windows Server 2019 -
Getting data from the ctrl object for my custom HTML dashboard. -
I have queries from 2 data sources: SQL Server and OPC UA.
What happened?
There’s an error in the HTMLCtrl object: “Cannot read properties of undefined (reading ‘length’)”
Data should be embedded in the ctrl object. -
Can’t seem to find any similar issues.
